Oct 14, 2015 2:01 PM UTC
How to get primary attachment file in the CheckinObjectFormProcessor?
Hi!
I need to customize CheckinObjectFormProcessor. I need to get primary attached file that user insert in the checkin wizard. I've created my own CIObjectFormprocessor that extended OOTB CheckinObjectFormProcessor:
public class CIObjectFormProcessor extends CheckinObjectFormProcessor
  public FormResult doOperation(NmCommandBean paramNmCommandBean, List<ObjectBean> paramList) throws WTException
     FormResult localFormResult = new FormResult();
     localFormResult.setStatus(FormProcessingStatus.SUCCESS);
      // Need there to get new primary attachment file
     localFormResult = super.doOperation(paramNmCommandBean, paramList);
     return localFormResult;
localObjectBean.getParameterMap() can give me the Map with a lot of properties. But I can't to get the file I need. Please help.
ShirishMorkhade
Jan 5, 2017 12:56 PM UTC
Hi M Bagryanov‌,
you can try something like this:
/* (non-Javadoc)
  * @see com.ptc.windchill.enterprise.doc.forms.CreateDocFormProcessor#doOperation(com.ptc.netmarkets.util.beans.NmCommandBean, java.util.List)
  @Override
  public FormResult doOperation(NmCommandBean arg0, List<ObjectBean> arg1) throws WTException {
       System.out.println("*** I am in doOperation method");
       HashMap map=getFormData(arg0);
       java.util.Set setOfKeys = map.keySet();
       java.util.Iterator iterator = setOfKeys.iterator();
       while (iterator.hasNext()) {
            String key = (String) iterator.next();
            Object value = (Object)map.get(key);
            System.out.println("\nKey: "+ key+", Value: "+ value);
            //PRIMARY_FILE_wt.content.ApplicationData:1423826261835_filePath
            if (key.startsWith("PRIMARY_FILE_wt.content.ApplicationData") && key.endsWith("_filePath")) {
                 String valueoffile = value.toString();
                 System.out.println("\t *** File is --- " +valueoffile);
                 File file = new File(valueoffile);
                 System.out.println("\t *** File Name - "+file.getName());
       return super.doOperation(arg0, arg1);
  @SuppressWarnings("unchecked")
  protected static HashMap getFormData( NmCommandBean clientData ) throws WTException {
       HashMap formData = new HashMap();
       Map comboBoxData = null;
       Map radioData = null;
       Map textData = null;
       Map textAreaData = null;
       comboBoxData = clientData.getComboBox();
       radioData = clientData.getRadio();
       textData = clientData.getText();
       textAreaData = clientData.getTextArea();
       Map checkedData = clientData.getChecked();
       Map uncheckedData = clientData.getUnChecked();
       if (checkedData != null) {
            Iterator itChecked = checkedData.keySet().iterator();
            while (itChecked.hasNext()) {
                 formData.put(itChecked.next(), Boolean.TRUE.toString());
       } // end if checkedData
       if (uncheckedData != null) {
            Iterator itUnchecked = uncheckedData.keySet().iterator();
            while (itUnchecked.hasNext()) {
                 formData.put(itUnchecked.next(), Boolean.FALSE.toString());
       } // end if uncheckedData
       if(comboBoxData != null) {
            System.out.println("Prniting the comboBoxData::::" +comboBoxData);
            formData.putAll(comboBoxData);
       if(radioData != null) {
            System.out.println("Prniting the radioData::::" +radioData);
            formData.putAll(radioData);
       if(textData != null) {
            System.out.println("Prniting the textdata::::" +textData);
            formData.putAll(textData);
       if(textAreaData != null) {
            System.out.println("Prniting the textAreaData::::" +textAreaData);
            formData.putAll(textAreaData);
       return formData;
It will give you an file name which user selects in wizard.
I hope this helps you.
Shirish
