May 28, 2015 12:42 PM UTC
How to get request object in workflow robots?
Hi!
I need to get data from request object inside the expression robot. How can I get it?
Thanks!
May 28, 2015 5:16 PM UTC
Check out the ChangeService2 API (in wt.change2 package) which has methods to support your use case.  ChangeService2 methods can be called by ChangeHelper2.service.anyMethod().  Methods of interest are most likely getChangeablesBefore() to get Affected Objects and getChangeablesAfter() to get Resulting Objects.  Note - I've left out the parameters for simplicity so refer to the JavaDoc.
Jun 2, 2015 10:53 AM UTC
Hi Keir!
I mean HttpRequest object. Sorry for bad question.
