May 15, 2023 12:48 PM UTC
How to get Team Members and Role information from Container
As per the original post.
We also built a SQL query for this, but does anyone have this as a QML file to import?
OliverDroop
May 22, 2023 12:43 PM UTC
Here is some starting point. It lists the roles and users assigned, Problem is for group2role assignments. Then you will need to loop through the groups to get down to the principal. Therefore you might need a custom class to report this correctly.
