Jun 27, 2014 8:08 AM UTC
How to get text field values in formProcessor?
Hi!
Anybody know how to get text field values, that i was inserted in some wizard, in the formProcessor that will handle this wizard?
Jun 27, 2014 8:37 AM UTC
nmCommandBean.getText().get(...)
23-Emerald II
Jul 1, 2014 4:40 PM UTC
Anton, did Vasiliy's suggestion get you what you needed?
Jul 3, 2014 9:43 AM UTC
No.
This method return null value. I can't find something about getting text fields values from wizards in customization guide. May be you have any manuals?
2-Explorer
Jul 10, 2014 9:52 PM UTC
If you know the parameter name, you can use something like this:
String myStringValue = nmcommandbean.getTextParameter("myStringParamKey");
Or you can get the parameter map and pull it from there:
HashMap<String,Object> params = ((ObjectBean)list.get(i)).getParameterMap();
Iterator<String> iterator = params.keySet().iterator();
while (iterator. hasNext()) {
String key = (String) iterator.next();
String[] valueArray = (String[])params.get(key);
if (key.contains("myStringParamKey") && !(key.contains("___old"))) {
String myStringValue = valueArray[0];
Jul 14, 2014 11:16 AM UTC
Thanks, Teresa! I'll try it later.
Jul 16, 2014 6:29 AM UTC
If the jsp is custom jsp then its recommend to use wrapper tag from tag lib to create "TextBox" or If using HTML tag for input, the tag name must be following style for being read at NmCommandBean. “null___[attribute name]___textbox” If you want to use combo box, you must set name like following for NmCommandBean. “null___[attribute name]___combobox”
Kauhsik
