Apr 26, 2023 6:54 AM UTC
How to hide attributes from Search Criteria and Table Views?
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.10
jbailey
18-Opal
Apr 26, 2023 12:02 PM UTC
Table views should be the easy one, create a custom table view. For search criteria, probably will be some customization unless you want to hide the attributes anywhere in the system for a specific group of people...
If that is the case, you can use a profile and select which attributes you want to hide for those people....
GregoryPERASSO
Apr 26, 2023 1:43 PM UTC
If the need is the ability to define technical or internal attributes not exposed nor usable by End Users,   it could be a nice idea for PTC to have this option also in the Type Manager .
Some other PLM platform allow to define this in their low-code data model  module
jbailey
18-Opal
Apr 26, 2023 1:54 PM UTC
If it is a group of end users with a specific set of attributes across the entire system, I would use the profile method I suggested above.  I would create a group that encompasses all non-admin users and use the group in the profile
18-Opal
Jun 7, 2023 1:44 PM UTC
Hello ShreyaPatil,
I'm Charles from PTC Technical Support in Europe: Was the information provided helpful somehow? Or may I suggest you open a new case for this question?
KR,
Charles.
