Nov 25, 2014 5:43 AM UTC
How to implement a DataUtility on IBA which is in PartUsageLink
There is an IBA created in Part Usage Link to get some information about the Link object. I am able to add this IBA in Part Usage Link. But i want to render this IBA with a Drop Down list.
Will it be possible to render IBA (in a custom way) in the Part Usage Link in PSB
For your information, I am using Windchill PDMLink 10.2
Thanks in Advance.
Thanks & Regards
Gnanamuthu Lucas
TZ_01Answer
Dec 10, 2014 5:40 AM UTC
Its unfortunate.Windchill 10.2 PSM using degisn by GWT and ExtJs . its not support Datautiliy.
I try to do this way. The datautility render result only display in "INPUT TEXT" value.
Nov 28, 2014 7:48 AM UTC
You can add a data utility to your IBA using type and attribute manager.
TZ_011-VisitorAnswer
glucas1-VisitorAuthor
Dec 10, 2014 5:55 AM UTC
Yes your answer is correct.
I tried to configure another way to register data utility. At that time my data utility is getting called by it is not rendering properly as i expected because of GWT ExtJs implementation on PSB.
Thanks for your reply.
