joe_morton
Jul 18, 2019 3:51 PM UTC
How to link a WTPart to another WTPart?
Is it possible to link a WTPart to another WTPart?
The scenario is for electrical connectors where a plug has its mating socket.
I don't see an out-of-the-box link for that, but I've heard of configurable links. Is that the way to go? Or is there a better way to capture the plug/socket relationship?
Jul 22, 2019 2:05 PM UTC
Configurable links are probably the right way, but please be aware, that the collections don't work. You need to control a save as, revise, etc. manually or by customization.
See also this discussion
What is the use of configurable links in windchill?
Jul 18, 2019 4:01 PM UTC
Build the completed unit as an assembly?
The structure will tie the parts together.
joe_morton
Jul 22, 2019 1:59 PM UTC
I appreciate the idea, but it's not ideal. A connector may end up being used in many assemblies. It would be hard to pick out which assembly was there just to show the desired link.
