Jun 19, 2023 8:22 AM UTC
How to listen to event on action only
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.2
I want to listen on an WTPart action for "Actions-> Edit Common attributes". I am able to listen to event "PersistenceManagerEvent.UPDATE" and object type WTPartMaster. But i am facing the issue that this event triggers on every CAD check-in.
I am not able to differentiate the event on action and check-in. Is there any way to difference the event ?
Jul 3, 2023 4:26 AM UTC
Was able to achieve from the workaround of find the modified date of the object.
Jun 19, 2023 8:29 AM UTC
@syalagudri
To be sure to get the right event, you could overwrite the forms processor class.
com.ptc.windchill.enterprise.part.forms.EditPartCommonAttrsFormProcessor
There you can do all the verifications or start the after processes for the selected object.
18-Opal
Jun 19, 2023 8:36 AM UTC
Hi @syalagudri ,
In the Listener class please add the condition to check whether it is a WTPartMaster object type or not.
if(obj instanceof WTPartMaster){
Jun 19, 2023 8:45 AM UTC
Added. But on check-in also i get the same object type so not able to differentiate.
18-Opal
Jun 30, 2023 4:44 PM UTC
Hello syalagudri,
I'm Charles from PTC Technical Support in Europe, I will provide you assistance on this question.
Can you review kb article CS147573 and let me know how it could help?
KR,
Charles.
syalagudri14-AlexandriteAuthorAnswer
18-Opal
Jul 3, 2023 9:19 AM UTC
Hello syalagudri,
Thanks for your feedback, and congrats to you for figuring out the solution.
Are there any details  you can share how it got resolved?
I will be grateful if you can send me this information.
KR,
Charles.
