Nov 29, 2022 4:32 PM UTC
How to Load Variance Object through loadfromfile utility
Need to bulk load variance objects. Please provide ways to achieve this functionality.
avillanueva
23-Emerald II
Nov 29, 2022 7:22 PM UTC
[Knowledge Hub] Windchill PLM - Data Loading
This article is for older version but I do not think csv2xml supports variances.  I had to do this for a project and I ended up creating my own loader via a Java command line program that took in a tab delimited file. Short answer, you cannot via loadFromFile.
rchandu5-Regular MemberAuthor
Nov 29, 2022 7:32 PM UTC
Could you please help me on the steps to create the custom loader to achieve this. Need to load variance objects in bulk.
Nov 29, 2022 7:53 PM UTC
As per article https://www.ptc.com/en/support/article/CS322524 it is not possible to load variance,
You can create a custom utility or loader to achieve the same. I can help with utility.
Regards
Ajit
