Mar 16, 2016 12:58 PM UTC
How to make a Custom Number Rule (Rule Algorithm) e.g., DOC-20160316-0012
Source:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
package ext;
import wt.pds.StatementSpec;
import wt.query.QuerySpec;
import wt.rule.algorithm.RuleAlgorithm;
import wt.doc.WTDocument;
import wt.enterprise.EnterpriseHelper;
import wt.fc.PersistenceHelper;
import wt.fc.QueryResult;
import wt.util.WTException;
import wt.inf.container.WTContainerRef;
import wt.doc.*;
import java.util.Date;
import java.util.Locale;
import java.util.TimeZone;
import java.text.*;
import java.util.*;
public class CustomNumberRule implements RuleAlgorithm {
     static int maxCount=0;
     public Object calculate(Object args[], WTContainerRef container) throws WTException {
         int count =0;
         //Generate today's date. Example:20160316
         SimpleDateFormat simpleDateFormat = new SimpleDateFormat("yyyyMMdd", Locale.KOREA);
         Date currentDate = new Date();
         String date = simpleDateFormat.format(currentDate);
         //QuerySpec For wt.doc.WTDocument
         QuerySpec qs = new QuerySpec(wt.doc.WTDocumentMaster.class);
         QueryResult qr = PersistenceHelper.manager.find((StatementSpec) qs);
//         System.out.println("Number of WTDocument Masters: " + qr.size() + "\n\n");  //test
         WTDocumentMaster master = null;
         int maxNumber=0;
         //Count documents i.e., DOC-20160316
         while (qr.hasMoreElements()) {
             master = (WTDocumentMaster) qr.nextElement();
             if(master.getNumber().contains("DOC-"+date)) {
                 ++count;  //Number of document formatted in DOC-yyyyMMdd
                 //Parse document's number
                 int number = Integer.parseInt( master.getNumber().subSequence(13, 17).toString() );
                 if(maxNumber < number) {
                     maxNumber = number;
                 System.out.println("****Number:" + number    );
                 System.out.println("****Max Number:" + maxNumber    );
         System.out.println("@maxCount:" + maxCount); //test
         System.out.println("@count:" + count); //test
         if(maxCount < maxNumber) {
             maxCount = maxNumber+1;
         }else  {
             maxCount++;
         System.out.println("#maxCount:" + maxCount); //test
         System.out.println("#count:" + count); //test
         String num = "";
         if (args != null && args.length > 0) {
             num += args[0].toString();  //argument from OIR Rule of Product Document(제품문서)
             num += "-";
             num += date;
             num += "-";
             num += String.format("%04d", maxCount);
         }else {
             System.out.println("There are no arguments.");
              System.out.println("Product Document's Number: " + num); //print
         return num;
Colored by Color Scripter
cs
Object Initialization Rule (OIR):
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
            <AttributeValues objType="wt.doc.WTDocument">
               <!-- set the folder -->
               <AttrValue id="folder.id" algorithm="com.ptc.core.foundation.folder.server.impl.FolderPathAttributeAlgorithm">
                  <Arg>/Default</Arg>
               </AttrValue>
               <!-- set the lifecycle -->
               <AttrValue id="lifeCycle.id" algorithm="com.ptc.core.foundation.lifecycle.server.impl.LifeCycleTemplateAttributeAlgorithm">
                  <Arg>
                     <!-- Translation of the word "Basic" must be the same as the translation done in commonLifeCycles.xml -->
                     <?loc-begin key="BASIC_LIFECYCLE_NAME" maxlen="30" match="commonLifeCycles.xml:BASIC_LIFECYCLE_NAME"?>Basic<?loc-end?>
                  </Arg>
               </AttrValue>
               <!-- set the team template -->
               <AttrValue id="teamTemplate.id" algorithm="com.ptc.core.foundation.team.server.impl.TeamTemplateAttributeAlgorithm">
                  <Arg>Default</Arg>
               </AttrValue>
               <!-- set the number to a generated number -->
               <AttrValue id="number" algorithm="ext.CustomNumberRule">
                  <Arg>DOC</Arg>
                  <Arg>{GEN:wt.enterprise.SequenceGenerator:WTDOCUMENTID_seq:4:0}</Arg>
               </AttrValue>
               <!-- set the version info to a generated version info -->
               <AttrValue id="MBA|versionInfo" algorithm="com.ptc.core.foundation.vc.server.impl.VersionInfoGenerator">
                  <Arg>wt.series.HarvardSeries</Arg>
               </AttrValue>
               <!-- set the doc type - enumerated type, this field is no longer displayed in the UI so just default it -->
               <AttrValue id="docType" algorithm="wt.rule.algorithm.EnumTypeConstant">
                  <Arg>wt.doc.DocumentType</Arg>
                  <Arg>$$Document</Arg>
               </AttrValue>
               <!-- set the department type - enumerated type, this field is no longer displayed in the UI so just default it -->
               <AttrValue id="department" algorithm="wt.rule.algorithm.EnumTypeConstant">
                  <Arg>wt.doc.DepartmentList</Arg>
                  <Arg>ENG</Arg>
               </AttrValue>
               <!-- specify AttrConstraint tag -->
               <AttrConstraint id="lifeCycle.id" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
                  <Value algorithm="com.ptc.core.rule.server.impl.GetServerAssignedConstraint"/>
                  <Value algorithm="com.ptc.core.rule.server.impl.GetImmutableConstraint"/>
           </AttrConstraint>
           <AttrConstraint id="lifeCycle" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
           </AttrConstraint>
           <AttrConstraint id="folder.id" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
                   <Value algorithm="com.ptc.core.rule.server.impl.GetServerPreGeneratedValue"/>
           </AttrConstraint>
           <AttrConstraint id="number" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
           </AttrConstraint>
           <AttrConstraint id="teamTemplate.id" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
           </AttrConstraint>
           <AttrConstraint id="teamTemplate" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
           </AttrConstraint>
           <AttrConstraint id="organization.id" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
                   <Value algorithm="com.ptc.core.rule.server.impl.GetServerPreGeneratedValue">
                      <Value algorithm="com.ptc.windchill.enterprise.org.server.impl.OwningOrgDefaultAlgorithm"/>
                   </Value>
           </AttrConstraint>
            </AttributeValues>
cs
