7-Bedrock
May 31, 2022 3:02 AM UTC
How to Modify Default Units
How to Modify Default Units From OHM to OHM(DCR).
Thanks.
7-Bedrock
Jun 2, 2022 4:46 AM UTC
This reply is from Akim in Shanghai.
Would you please refer below article try change to the Default Unit for your system ?
How to add custom Unit or hide OOTB "default unit" for WTParts in Windchill PDMLink
avillanueva
23-Emerald II
May 31, 2022 1:08 PM UTC
Are you looking to change the display name? Or are you defining a new unit?  If the latter, you can create a new unit with that name.
WW_81370447-BedrockAuthorAnswer
7-Bedrock
