Dec 26, 2013 7:23 AM UTC
How to Override windchill part
Hi
Can anybody please let me know is there any way to override the new version of windchill part with the old one.
exa. I have created the ABC ASM in windchill and its version is 1.2, now i made some structure change in it and its version became 1.3, later i thought old version is correct, is it possible to go back to old version by overriding the new one?
Dec 26, 2013 9:28 AM UTC
Hi Shyam.
Try to delete your asm. Before submitting select radiobutton like "Delete only latest iteration of the object"
Dec 30, 2013 7:27 AM UTC
Hi Anton
actually Idon’t have rights to delete from wind-chill, those rights given to only leads.
so instead of asking the leads to delete those is there any other way,please suggest.
Feb 18, 2015 5:01 PM UTC
Check out 1.2 and then check it back in as 1.4, assuming you have rights to check out non-latest iteration.
23-Emerald II
Feb 24, 2015 12:57 AM UTC
You should be able to check out non-latest versions of your part as long as the Create and Edit > Allow checkout of non-latest iterations is set to an appropriate value in Site preferences (allow checkout or throw overridable conflict). When the object is checked back in it will become the latest.
