Jul 17, 2023 12:54 PM UTC
How to programmatically move all revisions and versions of objects by Expression
Hi All,
I have tried with this Expression (CS152791), but it is not move all the previous revisions. It will move only last 2lastest versions of object.
Kindly help me out to move all revision and versions by expression.
Prashanth
HelesicPetr
Jul 18, 2023 8:27 AM UTC
Hi @Prashanth_0108
So try to search previous versions that were not moved and use the api to move them.
You may go through all revisions
PetrH
Emeritus
Jul 17, 2023 1:25 PM UTC
Hi Prashanth_0108,
Thank you for your question.
I encourage you to bring more details and context to your initial inquiery. For example, screenshots are useful to better understand what you are trying to do and will also increase your chance to receive meaningful help from other Community members.
Jul 18, 2023 4:55 AM UTC
Hi Archila,
Kindly check the snapshots and i am using this expression for moving the object from one folder1 to folder2.
// Check if a PBO has been assigned to the process
if (primaryBusinessObject !=null) {
try {
wt.folder.Folder f = wt.folder.FolderHelper.service.getFolder( "/Default/Obsolescence",((wt.inf.container.WTContained)primaryBusinessObject).getContainerReference());
//move the PBO to the test folder
wt.folder.FolderHelper.service.changeFolder((wt.folder.FolderEntry)primaryBusinessObject, f);
catch ( wt.util.WTException wex ) {
  System.out.println( "Cannot move "+ primaryBusinessObject.getDisplayIdentifier( )+" because "+ wex.getLocalizedMessage());
else
 // if a PBO has not been assigned to the Process
 System.out.println( "Primary business object is NULL");
Prashanth
HelesicPetr
Hi @Prashanth_0108
PetrH
