6-Contributor
Dec 4, 2023 10:16 AM UTC
How to propagate custom properties to log4jMethodServer file from a property file in Windchill 12.1
Hi Team, Can you please help me to propagate custom properties to log4jMethodServer file from a property file? I tried with declarations.xconf file to refer a property file, and xconfmanager -p to propagate values to log4jMethodServer file. But it didn't work.
HelesicPetr
Dec 4, 2023 12:00 PM UTC
Hi @AK_10341824
do you define the target file for the properties?
What exactly is the log4jMethodServer file?
usually if tou want to add a properties from own xconf file you should add a reference to that file in site.xconf  declaration.xconf is not bad place where to use the declaration but I would advice to use site.xconf
 you can create own file with definition and add a reference in site.xconf
<ConfigurationRef xlink:href="myCustom.xconf"/>
and place the file to the Windchill folder where the site.xconf is placed.
 example of own file
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE Configuration
 SYSTEM "xconf.dtd">
<Configuration xmlns:xlink="http://www.w3.org/1999/xlink">
 	 <Property name="logger.Integration.name"
 overridable="true"
 targetFile="codebase/WEB-INF/log4jMethodServer.properties"
 value="cz.aveng.Integration"/>
	 <Property name="logger.Integration.level"
 overridable="true"
 value="DEBUG"/>
 </Configuration>
PetrH
HelesicPetr
Hi @AK_10341824
 example of own file
 SYSTEM "xconf.dtd">
 overridable="true"
 overridable="true"
 value="DEBUG"/>
 </Configuration>
PetrH
6-Contributor
Dec 21, 2023 11:49 AM UTC
Hi @HelesicPetr, I tried with declaration.xconf earlier, it was not propagating the property correctly. Later used site.xconf. From site.xconf used configurationRef for the target xconf file. It worked fine then.
