Mar 16, 2016 1:25 PM UTC
How to put data into Excel sheet by using Apache POI
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
//Apache POI
package ext;
import java.io.File;
import java.io.FileOutputStream;
import java.io.IOException;
import java.lang.reflect.Field;
import java.lang.reflect.InvocationTargetException;
import java.lang.reflect.Method;
import java.util.*;
import org.apache.commons.io.FileUtils;
import org.apache.poi.openxml4j.exceptions.InvalidFormatException;
import org.apache.poi.openxml4j.opc.OPCPackage;
import org.apache.poi.ss.usermodel.Cell;
import org.apache.poi.ss.usermodel.Row;
import org.apache.poi.ss.usermodel.Workbook;
import org.apache.poi.xssf.streaming.SXSSFSheet;
import org.apache.poi.xssf.streaming.SXSSFWorkbook;
import org.apache.poi.xssf.usermodel.XSSFSheet;
import org.apache.poi.xssf.usermodel.XSSFWorkbook;
import org.joda.time.DateTime;
import org.joda.time.format.DateTimeFormat;
import wt.epm.EPMDocument;
import wt.epm.EPMDocumentMaster;
import wt.fc.PersistenceHelper;
import wt.fc.QueryResult;
import wt.pds.StatementSpec;
import wt.query.QuerySpec;
import wt.util.WTException;
import wt.doc.*;
public class Test2 {
    static int count=2;
    public static void main(String[] args) throws WTException {
        QuerySpec qs = new QuerySpec(wt.doc.WTDocument.class);
        QueryResult qr = PersistenceHelper.manager.find((StatementSpec) qs);
        System.out.println("Number of WTDocument Masters: " + qr.size() + "\n\n");
        WTDocument master = null;
        XSSFWorkbook workbook = new XSSFWorkbook();
        XSSFSheet sheet = workbook.createSheet("WTDocument Sheet");
        Map<String, Object[]> data = new TreeMap<String, Object[]>();
        data.put("1", new Object[] {"DOC NAME", "DOC NUMBER"});
        while (qr.hasMoreElements()) {
            master = (WTDocument) qr.nextElement();
            data.put(String.valueOf(count), new Object[] {master.getName(), master.getNumber()});
            count++;
        //Iterate over data and write to sheet
        Set<String> keyset = data.keySet();
        int rownum = 0;
        for (String key : keyset)
            Row row = sheet.createRow(rownum++);
            Object [] objArr = data.get(key);
            int cellnum = 0;
            for (Object obj : objArr)
               Cell cell = row.createCell(cellnum++);
               if(obj instanceof String)
                    cell.setCellValue((String)obj);
                else if(obj instanceof Integer)
                    cell.setCellValue((Integer)obj);
        try
            //Write the workbook in file system
            FileOutputStream out = new FileOutputStream(new File("My_WTDocument.xlsx"));
            workbook.write(out);
            out.close();
            System.out.println("it is written successfully on disk.");
        catch (Exception e)
            e.printStackTrace();
Colored by Color Scripter
cs
