8-Gravel
May 14, 2023 3:01 PM UTC
How to read each constraint from file for Attribute
I get the below information when i call the function ((AttributeDefinitionReadView) typeAtribs).getAllConstraints() on type EPMDocument
[@@@ BEGIN CONSTRAINT Definition
loadID: null
contextId: com.ptc.core.lwc.server.LWCTypeDefinition:9906
attName: docSubType
conditions: null
conditionFor: null
deleted: false
rule: com.ptc.core.meta.container.common.impl.SingleValuedConstraint:com.ptc.core.lwc.server.LWCBasicConstraint:3348:null
ruleDataObj: @@@ BEGIN Rule Data Object
ruleData: -[ ]
@@@ END Rule Data Object
properties:
readViewId: null
@@@ End CONSTRAINT Definition
, @@@ BEGIN CONSTRAINT Definition
loadID: null
attName: docSubType
conditions: null
conditionFor: null
deleted: false
rule: com.ptc.core.meta.container.common.impl.StringByteLengthConstraint:com.ptc.core.lwc.server.LWCBasicConstraint:3348:null
ruleData: [0,200]
properties:
readViewId: null
loadID: null
attName: docSubType
conditions: null
conditionFor: null
deleted: false
rule: com.ptc.core.meta.container.common.impl.StringLengthConstraint:com.ptc.core.lwc.server.LWCBasicConstraint:3348:null
ruleData: [0,200]
properties:
readViewId: null
loadID: null
attName: docSubType
conditions: null
conditionFor: null
deleted: false
rule: com.ptc.core.meta.container.common.impl.DiscreteSetConstraint:com.ptc.core.lwc.server.LWCBasicConstraint:3348:null
ruleData: [ECAD-HOOK-PROPAGATE-DESIGN-ATTRIBUTE-VALUES,ECAD-HOOK-RETRIEVE-DESIGN-ATTRIBUTE-VALUES,ECAD-HOOK-GET-DESIGN-DIRECTORY,ECAD-HOOK-GET-DESIGN-ITEM-LIST,ECAD-HOOK-PRE-UPDATE,ECAD-HOOK-CREATE-DESIGN-FILES-LIST,ECAD-HOOK-VALIDATE-DESIGN,ECAD-HOOK-CREATE-ATTACHMENT-LIST,ECAD-HOOK-GET-NEUTRAL-FORMAT-ITEM-LIST,ECAD-HOOK-CREATE-GENERIC-BOM,ECAD-HOOK-CREATE-NEUTRAL-FORMAT-FILES,ECAD-HOOK-CREATE-VARIANT-BOM,ECAD-HOOK-CREATE-VIEWABLE,BULKTEMPLATE,CASTINGCAVITY,CMM,COMPOSITE,CONCEPT-MODEL,DESIGN,DIEFACE,EXPERTMACHINIST,EXTERNALSIMPREP,HARNESS,INTERCHANGE,MOLDCAVITY,MOLDLAYOUT,NCASSEMBLY,NCMODEL,NCPART,PROCESSPLAN,REGENERATED-BACKUP,SHEETMETAL,WELDMENT,SOLID,VERIFY,SKEL_MODEL,OTHER,PACKAGE,PRESENTATION,XREF,ADRAW,ILLUSTRATION,MANIKIN,MANIKIN_SEGMENT,CONTAINER,ECAD-DERIVED-OBJECT-FOR-ASSM,CGR,DRAWFORM,ASMCGR,TEMPLATE,CATGSCRIPT,CATSCRIPT,VBSCRIPT,REPORT,DOCUMENT,MOVIE,IMAGE,CONFIGURATION_MODULE,CONFIGURATION_ASSEMBLY,ECAD_ASM,ECAD_BOARD_PART,ALLINONECATPART,CV4MODEL,AUTHORING,REVIEW,LIBRARY_PART,PROJECT,CONFIG_FILE,INSTRUMENTED_ASSEMBLY,TRAY_ASSEMBLY]
properties:
readViewId: null
I wanted to know how to access for each specific constraint and its ruleData() using inbuild function or API:
Ex.
[0,200]
[0,200]
[ECAD-HOOK-PROPAGATE-DESIGN-ATTRIBUTE-VALUES,ECAD-HOOK-RETRIEVE-DESIGN...]
Thanks & Regards,
KU
HelesicPetr
May 15, 2023 1:29 PM UTC
Hi @KU_9877195
You need to manipulate with the output as a string.
First I would transfer it to several string arrays where separator is a coma with space", " or hole string ", @@@ BEGIN CONSTRAINT Definition"
You get array for each Constraint definition.
After that you can transfer it to string array with "enter separator" you get the parameters with values where separator is ":"
and so on.
rule data contain another array with data and another separator as a just comma "."
PetrH
