Feb 19, 2014 7:57 AM UTC
How to refresh wizard step
Hi.
I have a three-step wizard. On first two steps user can select wtparts and wtdocuments. On last third step the tree is created from previously selected objects.
If user returns to first or second step to change selection of documents, how to refresh the third-step tree with new data?
Thanks.
Feb 20, 2014 5:09 AM UTC
I tried to use beforeJS="myJsFunction" param in appropriate wizard action but i have an error
TypeError: wizardSteps[stepId].preloadJS is not a function
http://bntd.sniihim.ru/Windchill/netmarkets/javascript/util/windchill-all.js
2788
This error ocurs regradless of myJsFunction code.
I have a little experience in javascript and have no idea what to do.
Feb 20, 2014 5:34 AM UTC
beforeJS="myJsFunction" works only for first step, and does not work for next steps.
Why?
Mar 11, 2014 10:13 AM UTC
Hi Vasiliy,
For third step make preloadwizardpage false.
<action name="thirdStep" id="thirdStep" preloadWizardPage="false">
<command class="ext.custom.processor" method="" windowType="wizard_step"/>
</action>
Kaushik
Jul 2, 2025 11:45 AM UTC
Hi i am working on something same at the moment. Did you find a workaround for refreshing the third step with new data?
avillanueva
23-Emerald II
Jul 2, 2025 12:14 PM UTC
This is a very old thread. Recommend starting fresh thread and include details of your issue, errors, version. etc.
