Dec 9, 2016 12:55 PM UTC
How to register custom scheduled jobs
Hi.
I'm working with Windchill 10.2. I need to register my custom scheduled job.
Customization guide says;
     Then add the following to your wvs.properties.xconf file (edit as needed):
     <Property default="MyCustomJob" name="myJob.description"/>
     <Property default="ext.wvs.CustomJobs" name=" myJob.class"/>
     <Property default="myCustomJob" name=" myJob.method"/>
     <Property default="true" name=" myJob.enableOnContainers"/>
     <Property default="myJob" name="schedulejobs<N>"/>
But "wvs.properties.xconf" mentioned above says:
     WARNING: Do not modify this file after it has been installed.  Use xconfmanager to set, reset, or undefine properties for your installation
But customization giude says:
     xconfmanager is a command-line utility that is used to add, remove, and modify the properties in the Windchill property files.
And nonthing about managing *.xconf files.
So, i don't understand what should i do to register my scheduled job.
Can anyboby explain and provide me best way full example?
Thanks.
