May 9, 2015 6:48 AM UTC
How to Rehost PDM Essentials
Hi All,
Good Day To You..
I need to perform rehosting process to move PDM Essentials from one machine to another machine.
As I'm doing this for first time, I need step by step process to rehost.
I kindly request you to guide me to complete this process.
Thanks In Advance
Regards
Krishna Chaithanya
May 12, 2015 4:40 PM UTC
Checkout the Rehost Guide, https://support.ptc.com/view?im_dbkey=162020
Not sure why it doesn't show up as a PDME admin guide, but the process should be the same.
May 12, 2015 10:24 PM UTC
Yes, PDM Essentials uses the same rehost process as PDMLink, so you can use rehost guide that Dan linked to. Also, see CS178253
