Apr 10, 2015 10:30 AM UTC
how to remove recover failed installation
Currently windchill 10 pdmlink is running and i tried of adding projectlink using solution installer as optional installation. had some errors and now some of services and third party services got corrupted . now i need to repair it
Apr 16, 2015 8:36 PM UTC
What sort of errors did you run into?
If you re-run the PSI, it should detect the failed installation and prompt you to recover it.
rtj1-VisitorAuthor
Apr 17, 2015 6:49 AM UTC
This is the error i am getting. I think some problem with the Pjl file i downloaded.
Apr 23, 2015 8:54 PM UTC
Did you try redownloading the project link install file? Did that allow the install to complete successfully?
If it's still failing, then the PJL_PtcInstall.log should give a better idea of what's causing the failure. The log is located in the install/logs/ directory inside your Windchill directory.
