Feb 24, 2016 11:55 AM UTC
How to remove soft attribute(IBA) which are present on WTPart Object
How to remove attribute(IBA) which are present on WTPart Object using code.
for e.g.  0001 Part has IBA source with value make need to remove the category IBA from Part 0001 from the code
Feb 24, 2016 9:38 PM UTC
Hi there,
The Type and Attribute Manager function should give you access to all the attributes that are connected to the WT Part object. You can easily hide the attribute to not lose any historical data, but if you really want it gone permanently you also have the option of deleting the attribute off of the WT part from there as well.
Hope that helps,
Daryl
