Nov 16, 2026 4:38 PM UTC
How to Report Vendor from Query Builder?
I’m using query builder to build a customized BOM report. I have the report correctly giving me the part structure with all properties, but I cannot get the part vendor to show up. The sourcing relationship breaks the report and it returns nothing when added. However, I can use the same relationship in a standalone report and it returns the vendor.
    MarcoTosin
    Nov 16, 2026 5:12 PM UTC
    You didn't specify which module you're referring to when talking about the vendor, but I assume it's SuMa.
    In that case, you might find this HUB article on SuMa reports helpful:
    https://www.ptc.com/en/support/article/CS385132
    And you'll probably also need to use some outer joins, which I don't see in the image you attached.
    How can an Outer Join be used when creating a report
    Marco
