May 31, 2017 9:01 AM UTC
how to restrict legacy revisions for new part creation
We have Revision Series loaded in system with some legacy=true value, so that those revisions can be imported for legacy data, i.e. I,O,Q,S,X,Z. At the same time we have added Revision attribute and enabled RevisionPicker in New Part Creation Form, so that user can enter required revision manually . Also in preference settings we have set this preference Allow Override On Revise = yes so that user can give required revision while revise, e.g. bumping up revision skipping next available be default.
Due to these settings, system is allowing to create new parts with Revision which are defined as legacy=true. But we dont want system to allow to create parts with these values. Any suggestions how can we restrict legacy revisions for new parts.
2-Explorer
Jun 1, 2017 11:32 AM UTC
I remember running this to the same issue and PTC mentioned that it is an expected behaviour. The only way to get around this is by adding a customization, like a validator
rmane-21-VisitorAuthor
Jun 1, 2017 2:53 PM UTC
Even for me PTC gave same reason, works as per spec, but they are not able to give us valid technical reason on this. I saw many customer have reported this issue and PTC need to come up with the solution either by fixing the issue or by coming up with new preference setting to make it work.
Below is the enhancement request raised by one more customer. I think we all should go and vote for it.
Legacy Revision Use Warning Request
