Nov 30, 2023 7:19 AM UTC
How to restrict type from dropdown (or TypePicker ) when creating new document?
Hello Everyone,
I am trying to restrict some softtype from dropdown list when creating new documents.
Can you please tell me how to restrict the types?
FYR :
1. File Name : createDocumentSetTypeAndAttributesWizStep.jsp
<jca:configureTypePicker>
<p:pickerParam name="filterType" value="wt.doc.WTDocument|com.ptc.InterferenceDetectionDefinition"/>
</jca:configureTypePicker>
above line will work for OOTB document type and won't show "Interference Detection Definition"  document  type in dropdown list.
but won't for custom type as like below example :
<p:pickerParam name="filterType" value="wt.doc.WTDocument|ext.test.softType|ext.test.softTypeTest"/>
If someone knows please share how to achieve this?
Thanks.
HelesicPetr
Nov 30, 2023 8:43 AM UTC
Hi @netaji.mohite
Can you share what wizard do you try to customize?
Or do you create own wizard ?
The OOTB option is setting the instantiable parameter in type and attribute management and it has to work OOTB. @Fadel has described how to do so.
If the setting does not work then I guess you customize something that does not work properly.
PetrH
Fadel
23-Emerald II
Nov 30, 2023 8:09 AM UTC
set that type as non-instantiable in type and attribute manager
PS this will also hide the type from policy administrator
Buiꓘa
Nov 30, 2023 8:19 AM UTC
Thanks @Fadel
Tried this to set  non-instantiable, but no works.
Still the type is visible in dropdown list.
Fadel
23-Emerald II
Nov 30, 2023 8:20 AM UTC
What version are you using, are you sure you have save after editing the type ?
Buiꓘa
HelesicPetr
Hi @netaji.mohite
PetrH
