How to Retrieve the First Start Time of a Repeated Workflow Activity in Windchill?
Hi Team,
I have a requirement to retrieve the first/original Start Time of a workflow activity in Windchill.
The same workflow activity can be executed multiple times due to rework or workflow routing.
For example:
Execution 1:
Start Time : 10-NOV-2026 10:48
Execution 2 (after rework):
Start Time : 12-NOV-2026 11:17
Execution 3 (after another rework):
Start Time : 15-NOV-2026 09:30
My expected result is:
Plain Text
First Start Time : 10-NOV-2026 10:48
Currently, when working with WfActivity and WorkItem, I am getting the Start Time from the latest/current execution.
My requirement is to retrieve the first-ever Start Time, even if the same activity has been executed multiple times due to rework.
Could you please suggest:
- How can I retrieve the historical executions of the same workflow activity?
- How can I identify the first/original Start Time?
- Is
WFSTATEEVENTAUDITwithTRIPCOUNTthe correct approach for identifying previous executions? - Is there a supported Windchill Java API to retrieve this information instead of directly querying the workflow database tables?
If possible, please share a sample Java API/code example.
Thanks in advance.
