Jun 22, 2015 5:26 PM UTC
How to Rework from the Audit step in the CN and Re trigger the Change Task
I am working on a workflow and a key requirement is that if a user in the Audit Task in the Change Notice decides to choose "rework" I need the workflow to re trigger the change task and run through the assignee and reviewer tasks again.
I can't figure out how to get back into the Change Task.  Does anyone know how to do this?
Jun 22, 2015 8:01 PM UTC
If the Change Activity (aka Change Task) has already made it to the Resolved state, as it is in the OOTB CN/CA workflow, no can do as far as I'm aware.
We currently have a workflow where the Auditor can choose rework on the entire Change Notice, but it doesn't use the Change Activity for the rework process. Instead, any rework from the Auditor goes to one person who then reassigns it as necessary. After rework is completed, it goes to that same person to either review it himself or to reassign the review process. Not very elegant, but it's the best we could come up with using some of the limitations in the Change Management workflows.
One thing I played around with previously is to move the Audit task into the Change Activity instead of having it in the Change Notice. If that were the case it would be easy to put in a rework link loop. The drawback, of course, in cases where there are multiple Change Activities the Auditor would get multiple reviews. This would depend upon your specific requirements.
I've heard that Change Notices can be iterated, but I'm not sure if the Change Activity can be or if doing so would then fire off the CA and how that might interact with the CN and any synchronize robots.
rhermann1-VisitorAuthor
Jun 22, 2015 9:18 PM UTC
Yeah I have used both of those approaches in the past with varying acceptance from the customer depending on their use case.  I was hoping someone would respond to this with a little more elegant solution.
Thanks for the input, at least I know I am not the only person struggling through this issue.
Jun 23, 2015 11:57 AM UTC
When setting mine up, I tried to explain that the Audit was just a review of the CN itself (the attached docs, the description, etc.) and was NOT a review of the CAD docs. The CAD doc review happened during the CA by the chosen reviewer.
That didn't fly so we ended up with what we have.
It would be nice to have something like this but I don't foresee it.
