11-Garnet
May 8, 2025 9:21 AM UTC
How to save a custom affected object attribute in a Change Request?
Version: Windchill 13.0
Use Case: How to save a custom affected object attribute in a Change Request?
Description:
"We created some custom attributes for the affected object in the Change Request. We are able to enter values for these attributes while creating the Change Request, but the values are not getting saved. How can we save the values to the attributes?"
Catalina
Community Manager
May 8, 2025 11:04 AM UTC
Hi @SB_10904295
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • How did you configure the custom attributes for the affected object in the Change Request? Can you provide details on the steps taken?
  • What specific steps do you follow to enter and save values for these custom attributes during the creation of the Change Request?
  • Are there any error messages or logs that indicate why the values are not being saved?
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Windchill looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina | PTC Community Manager
avillanueva
23-Emerald II
May 8, 2025 12:30 PM UTC
Can you share screen shots of your Type Manager where you added that attributes and the UI where you enter them? Should be as simple as this:
https://www.ptc.com/en/support/article/CS407306?source=search
In case table edits are needed:
https://www.ptc.com/en/support/article/CS270989?source=search
