May 31, 2024 7:42 AM UTC
How to see number of sheets in a Drawing from Windchill without opening the file?
Version: Windchill 13.0
Use Case: The number of sheets/pages on a drawing is not visible in a drawing's windchill object page, and can only be seen once opened in Creo View or when opening the drawing content in Creo.
Description:
Is there a simple way to make a drawing's page count visible on the object info page?
i.e. the number of sheets in a drawing.
I can imagine a custom attribute and custom java code that interrogates the drawing file content to come up with a sheet count, but wondered if there is anything out of the box.
Could it even be a matter of having the thumbnail render with a sheet count or indicator that it is multiple sheets (or how many sheets)?
May 31, 2024 1:38 PM UTC
Probably can do it with a simple relation and parameter/attribute.
The drawing has &total_sheets parameter that could be set to a designated attribute. Then modify the Information page to include the attribute.
It might require a relation and as we all know, drawings do NOT allow relations! This has been an Idea for years.
avillanueva
23-Emerald II
May 31, 2024 5:22 PM UTC
It would work but never a big fan of those type of solutions. It adds to much complexity. @icelynnin What's your use case? How would that information be used? The system has the information. It should be able to read the file and figure that out.
