Jan 20, 2016 10:43 AM UTC
How to see which slave node we are accessing in Windchill from UI?
Is there is a way, to get the username with slave node in windchill . For example Username@sl01
2-Explorer
Jan 20, 2016 4:29 PM UTC
I have used the method detailed in https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS142955 a couple of times to get the full name of the user. In the custom class, you can add a method to read the java.rmi.server.hostname from wt.properties which would give you the host name of the server. You can add a custom name for each of the nodes you have in, like node-1 or 2 based on value of java.rmi.server.hostname
Thank you
Binesh Kumar
