Jun 24, 2013 2:30 PM UTC
How to set OOTB Part Attributes, Version & Iteration, using java code (Windchill API's) ?
I have created a WTPart using Java code + Windchill API's. There are setter methods available for setting some attribute like Name, Number, Type, Source etc.
Is there any method / API to set the Version and Iteration of the created part through code ? Can I set the values of Version and Iteration to be say, C and 5 directly ? Or creating a default Part of A.1 and revising / checking out is the only option ?
It would be really helpful if someone could help me with Windchill API's / Code snippets to set Part Version / Iteration OR Revise / Check out a part till the desired Version / Iteration is reached.
mraneAnswer
Jan 12, 2015 9:08 AM UTC
Yes, it is possible to load objects out of sequence. For setting the version one can use VersionControlSErverHerlper API's as shown below.
VersionIdentifier vid = VersionIdentifier.newVersionIdentifier();
VersionControlServerHelper.setVersionIdentifier(the_versioned, vid, false /* validateIncreasing */);
Similarly for iteration one can use IterationIdentifier API's. As shown below
IterationIdentifier iid = IterationIdentifier.newIterationIdentifier();
VersionControlHelper.setIterationIdentifier(the_iterated, iid);
A detailed code snippet can be found at <WT_HOME>\src\com\wt\doc\LoadDoc.java
-Malavika
Jun 24, 2013 4:44 PM UTC
Jan 12, 2015 6:23 AM UTC
I wanted to assign version of EPMDoc object to WTDoc object while creation WTDoc.
Suppose EPMDoc has version A then WTDoc of same version should create in system.
is it possible?if so then plz let me know how i can achieve this through code.
mrane1-VisitorAnswer
-Malavika
