Dec 17, 2014 3:58 PM UTC
HOW TO SET THE Revisioning SCHEME IN WINDCHILL ?
Hi
How to set Revisioning scheme in windchill ?
We are not following ptc windchill default parameter to define revision in part template,
Instead we are mentioning revision as paramater name in tempalte ?
Dec 18, 2014 3:05 PM UTC
See Windchill Help Version Scheme
Dec 18, 2014 8:41 PM UTC
  • When you say "part"; are you referring to WTPart or EPMDocument .PRT?
  • Is your question about Creo parameters, or are you asking about Revision meta data stored in the the in Windchill data model?
  • For your parts, do you know if you are using file-based versioning or state-based versioning?
Do not want to make any assumptions on what you are asking for assistence on.
Thank you
