Oct 28, 2014 2:33 PM UTC
How to solve java error
How to sort out the below issue
Oct 28, 2014 5:45 PM UTC
What version of Internet Explorer are you using?
Oct 29, 2014 2:40 AM UTC
Internet Explorer 11.0 and creo 2.0
Oct 30, 2014 5:35 PM UTC
It looks like you might be running into the issue from CS150425. What maintenance release of Creo 2.0 are you using? IE 11 is only supported on Creo 2.0 M100 and later. Using IE 11 with Creo 2.0 M090 and earlier can produce the same error message that you are seeing.
Dec 5, 2014 2:06 AM UTC
set config.pro option
browser_limit_to_ie9_mode yes
