Oct 29, 2015 2:43 PM UTC
How to solve these referential integrity violation?
I have to delete a file part (called eliminate.prt), that file was in an assembly and after substituted.
I remove form Winchill cabinets all the old versions of the assemblies and relative drawings were that file was related, but I still can't eliminate that file.
The error message is in the picture below.
What is the solution?
Thanks!
Oct 29, 2015 7:52 PM UTC
The simple solution is to use a life cycle state that is hidden from all users except the Org & Site admins.
Decide on the life cycle state you wish to use.
Change the object to that state.
Go into Policy Administration and set the admins to full control of that object type at that state.
Set all other users to deny full control of that object type at that state.
When you do this users can't see it and can't open it. Assemblies that a user tries to open with that particular iteration will instead revert to using the latest iteration. If the assembly is trying to use the only iteration which is unavailable, the model will fail and the component will need to be removed from the model tree.
