Nov 26, 2025 4:57 PM UTC
How to Stop a Complete Task in a workflow based on resulting object state
I am using Windchill PDMLink Release 13.0 and Datecode with CPS 13.0.2.4
Is it possible to check a resulting objects (WTPart) state and if not set to Released stop a Complete Task in a work flow (with message if possible). And only let the Complete Task happen when Resulting object is Released.
    Fadel
    23-Emerald II
    Nov 27, 2025 4:03 PM UTC
    jsirrell10-MarbleAuthor
    Dec 2, 2025 7:33 AM UTC
    Thank you I will pass information to my Colleague
    joe_morton
    Dec 1, 2025 9:45 PM UTC
    You could also use the method described here: https://www.ptc.com/en/support/article/CS115274?source=search
