Jan 26, 2016 4:23 PM UTC
How to store Team object by code?
Hi to all!
I am storing the Team object like:
PersistenceHelper.manager.store(myTeam);
Then I can query this team by name, but RolePrincipalmap is empty.
Anybody know how to store team object correct? Thanks!
Jan 29, 2016 12:02 PM UTC
Hi guys!
Thanks for your answers.
I have solved this problem. If you need to store the Team object with non empty RolePrincipalMap you should:
1) Store the Team object like follow (pn is the PromotionNotice object):
Team newTeam = Team.newTeam();
  newTeam.setName(pn.getNumber() + "pnTeam");
  newTeam.setDomainRef(pn.getDomainRef());
  newTeam = (Team)PersistenceHelper.manager.save(newTeam);
2) Create and store RolePrincipalMap objects for all roles and users you need like follow:
RolePrincipalMap rpm = RolePrincipalMap.newRolePrincipalMap();
  rpm.setWTRoleHolder2(newTeam);
  rpm.setRole(role);
  rpm.setPrincipalParticipant(wtpr);
  PersistenceHelper.manager.save(rpm);
Then you can query your Team object and getRolePrincipalMap will return you current RolePrincipalmap
2-Explorer
Jan 26, 2016 4:48 PM UTC
You can use the API wt.team.TeamHelper.service
Thank you
Binesh Kumar
ShirishMorkhade
Jan 28, 2016 2:34 PM UTC
Anton,
Have you tried below API:
TeamTemplate teamTemplate = TeamTemplate.newTeamTemplate();
teamTemplate.setTeamTemplateIdentity(templateName);
teamTemplate.setContainer(container);
FolderHelper.assignLocation((FolderEntry)teamTemplate, folder);
teamTemplate.setEnabled(true);
teamTemplate = (TeamTemplate)PersistenceHelper.manager.store(teamTemplate);
return teamTemplate;
Shirish
Jan 28, 2016 5:16 PM UTC
Anton,
Do you want to store the Team Template, team instance or context team ?
can you  explain your requirement to store/create new team?
Shreyas
AntonBagryanov1-VisitorAuthorAnswer
Hi guys!
  rpm.setRole(role);
