Nov 13, 2015 12:46 PM UTC
how to trace the checked out files?
How to trace the checked out files?
Nov 13, 2015 1:39 PM UTC
Can you further explain what you mean by "trace"?  Are you looking to create a report that shows all checked out objects in Windchill?
Nov 13, 2015 5:27 PM UTC
yes, it is correct
Nov 13, 2015 6:33 PM UTC
If you're willing to do separate reports for individual object types, you can use the QueryBuilder function in Windchill to accomplish this (Site > Utilities > Report Management).  Here you can build a report on, say, EPMDocuments, to list all EPMDocuments in your system, their revision, iteration, and state, and only filter for those that are checked out.
Building these reports can be a bit tricky, as the interface is not the most intuitive tool.  I'd be glad to help and work with you and your company to implement this, or other reports or projects as well.  If you are interested, feel free to contact me directly at robert.sindelar@eccellent.com, or check out our website at www.eccellent.com.
