May 7, 2024 3:13 PM UTC
How to "transform" i.e. move, rotate... a group in Creo View MCAD?
Version: Windchill Below 11.0
Use Case: I need to make a selection of parts into a group in order to be able to easily select the same parts again later.
Description:
Description:
So I made this selection of a dozen parts into a group.
When I click on the group's name, the parts are selected again. However, I cannot seem to transform them.
I need to rotate the selected parts. How can I do that?
May 7, 2024 3:28 PM UTC
CreoView is not a CAD system, it is a viewer.
You will need to make your group in Creo and save it there.
VecTor10-MarbleAuthor
May 7, 2024 3:31 PM UTC
Thank you, but what is then the point of creating groups altogether in Creo View?
