How to Uninstall Windchill DS and Windchill PDMLink
Version: Windchill 12.1
Use Case: Uninstallation of windchill DS and Windchill PDMLink from windows systwm
Description:
Hi Everyone,
I had install windchill DS from PSI 11.2 and Windchill PDMLink from PSI 12.1 but getting some error while Installing FlexPLM so I want to Uninstall both windchill DS and windchill PDMLink from my system(Windows 11)  completely and want a fresh installation of 12.0 version of PDM link and 11.2 version of windchill DS.
So please guide me step by step process for uninstalling Windchill ds And Windchill PDMLink from my system
PS: I have installed these Windchill DS and Windchill PDMLink  using Microsoft sql server data base (2019 standard edition)
following this article but this isn't complete
Article - CS47990 - How to uninstall Windchill PDMLink On Windows platforms (ptc.com)
Thanks and Regards,
Lavkush.
What is the issue with the Uninstall? what exactly is the error you are getting when trying to install FlexPLM?
Hi @shussaini
I am not getting any issue while uninstalling flexPLM but actually want to the process of uninstallation of windchill and FlexPLM. I am getting error after installation of FlexPLM (Site is not responding error getting in method server log)  so my teammates asked to uninstall 12.1 version and install 12.0 version.
so that's why I want to uninstall it and then I will install 12.0 version after uninstallation of 12.1 version
Can you try the steps mentioned in CS46117.
regards
~Syed
My uninstall procedure is rather simplistic.
Windchill Server:
  1. Stop any services
  2. Delete services
  3. Delete the WindchillDS home folder
  4. Delete the Windchill home folder
  5. Delete the folders specified in Article - CS47990 - How to uninstall Windchill PDMLink On Windows platforms (ptc.com)
  6. Run RegEdit and remove all settings that point to the Windchill home folder
Oracle Server:
  1. Run the Oracle Deinstall.bat
  2. Reboot
  3. Delete the PTC folder
  4. Delete the Oracle directory
  5. Delete Oracle files in the user profile
  6. Run RegEdit and remove all settings that point to the Oracle install folder
Community Moderator
May 27, 2024
Hello @LY_10691079,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
