Mar 7, 2014 10:23 AM UTC
How to update the Softtype attribute and OOTB attribute of WTDocument
Hi can any one help me how I can update the WTDocument attributes I have some softtype also. currently I am using Update-Objects to update the objects I am looking for Windchill API
Mar 7, 2014 10:27 AM UTC
public static void updateAttributesValues(Persistable object, String[] attributeNames, Object[] attributeValues) throws WTException
if(attributeNames.length != attributeValues.length)
throw new WTException("The length of attribute names array is not the same as the length of attribute values array");
LWCNormalizedObject lwcNormalizedObject = new LWCNormalizedObject(object, null, null, new UpdateOperationIdentifier());
lwcNormalizedObject.load(attributeNames);
for(int i=0; i<attributeNames.length; i++)
lwcNormalizedObject.set(attributeNames[i], attributeValues[i]);
lwcNormalizedObject.apply();
Mar 7, 2014 1:24 PM UTC
By the way, LWCNormalizedObject is depricated in PDMLink 10.2.
WindchillJavadoc 10.2:
LWCNormalizedObject is deprecated and is planned to be removed in the next release. Use PersistableAdapter instead.
Mar 7, 2014 1:54 PM UTC
Hello Bjoern,
I am not able to search the PersistableAdapter class I am using Windchill 10.0 M010 can you tell me the package and if possible can you share code with me ?
