7-Bedrock
Apr 21, 2025 2:25 AM UTC
How to upgrade to Ldap with Active Directory
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.0.0
I installed Windchill 12.1's Ldap related active directory settings. I'm trying to upgrade from Windchill11.0 m030 version to 12.1, (DB Data = Windchill11.0) I imported the DB data, set db.properties to wtadmin, and when running Upgrademanager, Ldap > Initialize Upgrade doesn't proceed.
Here are the errors that I faced
Check JNDI Adapter's connection properties or provided inputs
Ldap Provider Url: ldap://CN=Manager:ldapadmin123!@plmopen.intelliantech.com:389/CN=Users,DC=plmopen,DC=intelliantech,DC=com Check if Directory Server configured for the adapter is running. The adapter must be configured properly to upgrade successfully. Please make the necessary changes.
    Apr 21, 2025 10:06 AM UTC
    Article - "Upgrade is failing during "Checking Default & Enterprise Adapters LDAP Connection" task in Windchill PDMLink": https://www.ptc.com/en/support/article/CS402941
