3-Newcomer
Mar 27, 2026 7:18 AM UTC
How to upload and use the IFX library on the Windchill by maintaining the own numbering for the Part
Version: Windchill 13.0
Use Case: To use the IFX library in the Creo for the Windchill fasteners and Also want to build standard fasteners library in the windchill from Fasteners available in the Creo IFX library.
Description:
Want to upload standard fasteners from the Creo IFX library to the windchill and also want IFX to fetch and use the fasteners form the windchill libraries when designer is using IFX tool in the Creo. But in the windchill the custom numbering scheme is configured for the standard parts in the windchill library. so also want to maintain that numbering scheme for the fasteners and they should be used by IFX library in the Creo when designer wants to assemble any fastener in his assembly.
What configurations are needed to implement this functionality ? and how to do this ?
Also is it possible to map the Creo parameter of the fastener parts directly to the windchill partslink classification attributes ?
Versions : Windchill 13.0.2.6 and Creo 11.0.0.0
