Feb 5, 2025 2:09 PM UTC
How to use tabSetKey to define order of custom created tabs(from UI)
Version: Windchill 12.1
Use Case: I've created custom tabs in the UI(by clicking the “+” icon on the tab set) on WTPart, and I want to define the order of these tabs. these UI through created tabs are not defined via an action model as the other tabs. How do I control the order of these tabs?
Description:
I want the Details tab to be 1st and, Structure to be 2nd. How do I control the order of these tabs?
Catalina
Community Manager
Feb 11, 2025 2:48 PM UTC
Hi @11025060
Thank you for your question.
Catalina | PTC Community Manager
RG-Alle12-AmethystAuthor
Feb 11, 2025 9:16 PM UTC
In article https://www.ptc.com/en/support/article/CS336436 it tells us what type the tab is if it is configured in *-actionmodelss.xml
Is there any other value for the ‘tabType’ parameter if the tab is configured through UI, instead of the xml?
joe_morton
Mar 21, 2025 3:22 PM UTC
Can't you just click + drag the tabs to reorder them? I know you can do that for your personal UI, but I'm not sure if that affects other users for public tabs.
