Jan 25, 2017 8:09 AM UTC
I am having trouble replacing a part in a part structure?The replace managements tab opens and when i select the part to be replaced and click OK it does not do anything
The replace managements tab opens and when i select the part to be replaced in 'alternates' and click OK it does not do anything
Jan 25, 2017 8:22 AM UTC
What you are describing is the use of Variants (Alternates and Substitutes).
If you want to replace a WTPart in a Structure, you will need to use Remove and Insert Existing or Insert New.
There is no Replace functionality available in the Structure tab.  You can use a Replace function in a Change Activity.
