Aug 10, 2015 1:49 PM UTC
I am seeing multiple associations of the same version of a drawing to a WTPart. Is there a way to only show a single association? What is causing this?
I have a couple, not all, WTParts that for some reason are showing multiple associations to the same version of a drawing.  For some reason the two instances I have investigated is has been four drawings.  I have tried manually editing the relationship and it did not resolve the issue.
Aug 23, 2016 12:02 PM UTC
Hi
Did you ever resolve this problem? We have the same behavior too. WTPart shows multiple drawings with the same revision and iteration.
pperry-21-VisitorAuthor
Feb 17, 2017 1:14 PM UTC
Sorry don't go hear as often as I should.  We did NOT resolve.
