18-Opal
Nov 24, 2017 4:42 AM UTC
i can't find change request object
Hi i'm SeonHo
You have created a change request.
However, the change request file is not visible
Through the search, there is a change request file like the picture.
If you view the information in the file and click on the location
Nothing...
Is Windchill not seeing the change request file?
If not, why not see the change request file?
TomU
TomUAnswer
Nov 28, 2017 12:36 AM UTC
See the video below.  Keep in mind that to edit the default "All" table view requires logging in as Site Admin.  If you don't have that permission, you can always save a copy of it (click on the disk icon) and just create your own custom version of "All".
Nov 24, 2017 10:31 AM UTC
Don't you have a filter ?
CHASEONHO18-OpalAuthor
18-Opal
Nov 27, 2017 12:18 AM UTC
if i set a All in filter then Object not shown..
but if set a Change Object in filter then object show
why is the object not displayed even if it is set to All?
thanks
TomU
Nov 27, 2017 1:28 PM UTC
Because "all" is not really "all".  You can edit the definition of the "All" table view to include these objects if you want.
Nov 24, 2017 9:00 PM UTC
Have you checked the changes folders?
