Sep 6, 2022 6:18 AM UTC
I can't run the windchill test system
I wanted to connect eclipse with windchill and create new classes. The connection was made and there were classes used in the com package. As soon as I created and uploaded new classes into the com package, the .class files in windchill were deleted and the test system stopped working. What can I do for it?
HelesicPetr
Sep 6, 2022 6:48 AM UTC
@OnurNalbantoglu
Try to do not compile the full com package, but compile just your custom one
It wouldn't delete others classes.
PetrH
HelesicPetr
Sep 6, 2022 6:34 AM UTC
Hi @OnurNalbantoglu
If classes were deleted because source files didn't exist that you need to restore them from backup or different system with same Version.
PetrH
Sep 6, 2022 6:36 AM UTC
I didn't take any backups. is there any other way i can undo the windchill changes.
HelesicPetr
Sep 6, 2022 6:41 AM UTC
@OnurNalbantoglu if the files were deleted from Windchill/codebase/com and source files does not exist?
install new system and copy missing class files. Or copy class files from production system if the system has same version.
If source files exist just compile full windchill/src folder. But I don't think it is good idea. Very often some src java files are out of date
PetrH
