May 18, 2015 10:21 PM UTC
I have 2 users, on different shifts, that need to use the same computer.
I have 2 users, on different shifts, that need to use the same computer. An error/warning pops up when attempting to register the server for the second user. It is regarding the cache being registered to another user.
What do I need to do to allow multiple users on one computer and not affect the other users workspaces?
May 19, 2015 8:19 AM UTC
This can be controlled using the following environment variables depending on whether you are using Creo or a 3rd part CAD app:
PTC_WF_CACHE
PTC_WF_ROOT
PTC_WLD_ROOT
Make sure when you define these variables that you use the username in there eg PTC_WF_CACHE = c:\windchill\%username%
That way whoever logs on will create their cache in a unique area
PTC_WF_CACHE
PTC_WF_ROOT
PTC_WLD_ROOT
May 19, 2015 4:00 PM UTC
Simon,
Thanks for the tip.
I used your %username% idea at the end of all the .psf files in the ....parametric\bin directory
ENV=PTC_WF_ROOT=C:\WINDCHILL_CACHE\%username%
Best regards,
Bryan
