Apr 20, 2017 6:03 AM UTC
I have modified OIR of an object but it is not reflecting
hi viewers,
I have modified the OIR of a Part type related to numbering. But it is not reflecting while I am going for creation of new part.
why it is happening...?
Apr 20, 2017 8:03 AM UTC
Did you check the related rule definitions in all contexts? Definition from rules at lower contexts will superceed that from higher contexts.
At product level OIR page, you can download the resulting composite rule to check
If you have soft types of part this can also have an influence the effective rule.
May 3, 2017 7:23 AM UTC
Hi Madhu,
I have entered over fifty numbering sequences into the database and successfully associated OIRs with all of them. Could you be more specific about what your process was/is, and I'll see if I can help.
Regards        Doug
mnalla1-VisitorAuthor
May 4, 2017 5:08 AM UTC
hi Doug,
Thank You for the response.
I corrected my mistake. Now I am able to print number sequence.
Regards
Madhu
