Dec 23, 2016 5:01 AM UTC
i have written a validator to check the duplicacy in the multi value attribute called "Production Plant" in both create and checkout and edit page...But i could accomplish this only in create page.
Since "create" action default validator is DefaultUIComponentValidator. i created a validator extending it.
For "checkoutandEdit" action default validator is CheckoutAndEditValidator. i created another validator extending it.
PFA the java files. But the problem is that it works for create acton but not checkout functions.
Need help with this
Logeshwar.J
Dec 28, 2016 6:58 PM UTC
Can you attach the xml for the service and action?
Dec 29, 2016 4:01 PM UTC
Hi Jamie,
     Sorry for the delayed response.
The property entry for the validators are as below
createPricolProduct - custom action name to create custom object
checkoutAndEdit - OOTB action name (used JcaDebug mode)
These property entries are added in the custom property file
<Service context="default" name="com.ptc.core.ui.validation.UIComponentValidator">
  <Option cardinality="duplicate" requestor="null" order="0" overridable="true" selector="createPricolProduct" serviceClass="ext.pricol.common.validators.MultiValueValidatorCreate"/>
  </Service>
  <Option cardinality="duplicate" requestor="wt.part.WTPart" order="0" overridable="true" selector="checkoutAndEdit" serviceClass="ext.pricol.common.validators.MultiValueValidatorEdit"/>
  </Service>
Logeshwar.J
logeshwar.jeyachandran@itcinfotech.com
Jan 3, 2017 2:18 PM UTC
You could try changing the requestor to "null". Also, I've had to add required="true" to the the action before. This document was created in response to a couple of cases I opened when I was having trouble getting validators to work.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS138656
Hope this helps. I'm out of ideas.
