Jul 18, 2024 4:16 PM UTC
I need to change the Solr admin password
Version: Windchill 12.0
Use Case: I need to change the Solr admin password
Description:
Team:
I need to change the Solr admin password, as discussed in another question.
Thanks Marco for finding an article https://www.ptc.com/en/support/article/CS353251
But it has at least two bugs in it:
  • bad path for jetty-util. OK, I found that one level lower, in the ext directory.
  • It says I should edit realm.properties, but I don't see any such file.
Do I need to edit realm.properties? Which directory should I put it in?
What is the correct xconfmanager command?
Here is the previous question
https://community.ptc.com/t5/Windchill/change-the-Solr-password/m-p/961350#M81210
Thanks !
avillanueva
23-Emerald II
Jul 20, 2024 8:01 PM UTC
You are setting the password on the SOLR index server right? You are not finding the realm.properties there?
rleir17-PeridotAuthor
Jul 23, 2024 4:12 PM UTC
Correct.  It's possible that I was supposed to create solr/server/etc/realm.properties, and I did so (it's a one-line file if I understand what's needed).  But I did not manage to get authentication working with this.
The solution that worked for me: get rid of the Solr installation and re-install using PSI.  There is some magic behind the scenes, and it does not create a realm.properties file.
20-Turquoise
Jul 23, 2024 7:51 PM UTC
That is what I have done also when I screwed up the solr password.
